RCBee's GSpeed V3 Honey Cheater Rig Build
Lookin good, lookin good. The bend in the links goes towards the axles. That front link looks like it may get into the motor, but u may get lucky n it tuck in there out of the way
Yeah so I did have them right ok! I might have to raise the trans or shorten the front front mount on the trans so either way it will work but may be a short pain in the Bee ass :). BUZZZZZ.....
Im working on it tonight so i'm sure ill post some link troubles!
I’ve seen some good arguments that you’ll get better clearance by putting the bend on the skid side.
Personally just from an aesthetics point of view I run the bend at the axle side
Interesting!!! We'll im about an hour away from that RC task so Il BEE Buzzzing back SOON.....
Links were spot on and the Shocks Too!!!!! Now the Transmission is killing me and I think its the extra forward option thats touching the motor to the chassis and im going to tweak the spacers and also instal the lil tugger 33t and see if I have some space! The link in the front clears the motor 90% but there should be a solution and I know it's in the transmission and motor mounting and also I might put some spacers to level out the width of the chassis with the skid, so back to the bench!!! BUZZZZZZ........
Messed around with the transmission last night and got it set up with the simple forward mounted variation and also put a TGH wedge and angled it but probably will level it out with 4mm spacers! So it still has a little tweak or 2 but I can now get the sliders painted up and start working on the electronics :) BUZZZZZ.....
Painted and sealed the sliders!
Now working on the body and the punks customs body mount :)
