Got a decent amount of work done over the weekend with the help of my dad and his shed full of tools!! I now have the frame of the flatbed mounted to the chassis. This was a bit more involved than expected as we had to make sure that all the holes drilled in the upright mounts lined up so the frame would sit straight and level. I've used a system of pushing rods through the mounts and the bottom of the frame to hold it on. On one side they'll have a washer and screw in the end of the rod and on the other end of the rod there is a body clip holding it on. This way I can easily take the frame off without tools.
I also got the rear axle in the mail too - Ultimate Scale Yota axle from RC4WD. Man those things are a work of art!!! As I suspected I will have to narrow the chassis so that is the next step. It has to be narrowed by somewhere between 5 and 10mm. I'm going to replace the cross braces and skid plate to do this. I've seen an aluminium skid plate for the SCX10/AX10 from STRC that looks like it can be cut down and I've also seen Delrin blocks on Ebay. Does anyone have any other ideas?
