Choosing a motor and ESC for your Wraith - Gearing Added!
wanted first a tekin combo with a tekin rs and a speed passion 7.5T brushless motor,but enede up with this combo:
Flux Vapor Pro Waterproof Speed Control - 106767 at HPI Europe
and
Flux Vektor 4000kv Brushless Motor - 106768 at HPI Europe
did i go wrong or i ended up good?is the combo that comes from factory on the savage xs flux
gearing will be 56/14 32 pitch with duratrax evader spur and RR pinion
As the first page said, you need a sensored speed control for any slow speed control. That system will not work. Also a 7.5 would have been way too fast. A 13.5 is about right.
not planing to do any crawling with that,i have a comp crawler,it's just for bashing.i had before a hobby king combo with a 11.5T motor and 45A esc,but it was whery slow.i wont be needing low speed,since it will be a basher/rock racer,planing on going fast
I like the ROC 412 motor would you guys think it's a MUST HAVE to change to a 32 pitch gear and bullet proof trans? Already have HD gears in axles and Gmade shafts. Thanks in advance.
GEARING!
Ok, I've answered the "what gearing for my xxxxx setup" question about 346 times too many. It's time to try and cover it as best I can here. *However the issue is that it goes hand in hand with motor choice, so this could get windy. These are all just starting points and there are hundreds or thousands of combinations. This is just a quick reference to get new people started in the right direction.
First off, when I refer to numbers in the format similar to "80/20", this means 80 tooth spur/20 tooth pinion. So, 84/14 would mean 84t spur/14t pinion, clear?
Are you running a stock motor? Short story, 84/16
If so then your gearing choices are limited but should be handled immediately if you are running the RTR. The stock gearing 80/20 (4:1 ratio) is too high of a ratio for the stock motor. The stock motor will not last you long anyway but if you want to extend it's life you need to regear, NOW. You are going to lose speed, there is just no way around it, I would suggest an 84/16 (5.25:1 ratio) setup.
Are you running a little higher speed brushed or brushless (Examples: 13t CrawlMaster, 27t TorqueMaster, 13.5 Redline)? Short Story, 56/12 32p (brushed) 56/14 32p (brushless)
Did you read the post #2? If you are running something I suggested (or similar to that) then the stock gear ratio is probably fine for you. The problem is that the little 48 pitch gears can't hold the power, you need to upgrade to 32 pitch gears. The stock ratio of 4:1 is fine, so you just need to equivalent in 32p. 56/14 is the same ratio. You can still run the stock spur cover with this setup as well. If you want a little more strength and tooth contact area you can go to 60/15 but the stock spur cover is likely a no go. Also with the 60/15 setup some motors require you to do a little filing on the motor plate to slide the motor over further. If you are running/wanting a Tekin Pro4 (or similar high power brushless) then see the last section.
Are you running something for mostly trails and crawling (example, 35t Torqemaster)? Short Story, 84/18
If you changed out your motor to something with a little more low end control and power then you likely could benefit from a better gear ratio. This isn't a must for a setup in this range however. The stock ratio is OK, but just not ideal in my opinion for someone who is looking to spend most of their time going slow. I do still feel that even if you're a rock crawler only that you will benefit from some wheel speed. I would suggest that if you do change gearing you start with an 84/18 setup.
Are you running a Tekin Pro4 (or similar high power brushless)? Short story. just read the rest of it!
If so then you likely need to build everything as strong as possible. I have gone this route personally. My suggestion is the 56t Gen3 metal spur and slipper setup from Robinson racing. To run this setup you will also need to buy a Traxxas slipper rebuild kit, all you will use from this kit is a black spring and a lock nut though. The next thing you need to buy is the Beefy top shaft from v84x4 here on RCC. I will include a link shortly. With the Pro4 you also must buy a pinion that has a 5mm bore and is hardened steel so that it wears more slowly against the steel spur gear, a 14t pinion is my suggestion. The Pro4 is very high power and you will likely spend the rest of your money replacing things in the truck since it was never meant to have something like this bolted into it!
That is my best first shot at handling this question. I'll come back and edit as required.
I am in the process of purchasing the Wraith Kit and am eyeing the Tekin Pro4. Everything that I am reading about it is getting me excited. I am going with the robinson racing lineup that you suggested 56t Gen3 metal spur and slipper. You mention a Traxxas Slipper rebuild kit (what is the part number?) and a beefy top shaft v84x4 (where can I get that?) You mention replacing other things in the truck since the motor is so powerful. What things do I need to replace? I assume the driveline. What specific parts need to be upgraded to support the Pro4? Also, any step by steps covering the replacement of the spur gear? I know that it is easy to do, but I am concerned about what I need to do with the Traxxas rebuild kit and the top shaft v84x4.
Ready my other guide on building a bullet proof wraith. You'll have to search for it.
thanks Harley! Already upgraded to HR steel gears and a RRP 48p 80t steel spur/slipper. Should I go ahead and upgrade the drive shafts w/the 13.5? Running 2s right now.
I finally made up my mind and ordered a 13t CrawlMaster Pro 540 and can't wait for trying it on my Wraith! "thumbsup"
I have a Turnigy XK3650-4400KV motor. My 13.5 Tekin is in my 2wd buggy.
Which pinion would you suggest 13t or 14t? I have a 54t spur.
I just picked my Tekin ROC 412 2300kv and a MMP. Have stock gearing and will change when I strip them. I'll have fun till then.
So I'm new to this rig and this hobby in general. I bought my Wraith to drive in the woods, but I enjoy crawling also (though not competitively).
I am thinking of getting the vanquish 10 pc links and their stage 1 kit. Now my question is- will this be too much weight and burn up my stock motor? How long can I expect to get out of my stock motor and gearing? I don't see the point in replacing it until it busts. I am already having to get a new servo and servo arm ya know.
Lower the gearing right away and the stock motor will last you a little while. Go to 87t spur and 14t pinion.
