HI THERE I NEED HELP ON GEARING AN AXIAL WRAITH FOR SPEED STRIGHT RUN IN THE SAND.
THE GOAL HERE IS ACHIEVE A BIGGER SPEED THAN AN E-MAX FROM TRAXXAS THAT CAN EASILY GO TO 40 MILES .
THE SETUP I HAVEN (MY PRO 4 HAVENT ARRIVED YET)
MAMBA MAX PRO COMBO SCT + 2400KV 4 POLE MOTOR.
I AM RUNNING STOCK SPUR GEAR AND A 28 PINION.
I WILL BE RUNNING IN 4S PLUGGED IN SERIES (TWO LIPO NANOTECH 5800MAH 40C)
SOMEONE LEND ME HIS SAND PAWS DIRECT FIT FROM TRAXXAS SLASH 12MM HEX.
THIS IS FOR A SPEED CHALLENGE THAT ITS GOING TO HAPPEN NEXT SATURDAY IN THE BEACH.
SO I NEED TO WIN THIS RACE.
I ALREADY RE-ENFORCED MY DRIVELINES, BUT I NEED THE PROPER GEARING TO BE CLOSE OF THE E-MAX.
I SAW THIS WEBSITE
R/C Calculations
BUT FROM THE GEARING I AM ITS GIVING ME 24.36 MILES
WHATS THE BEST GEARING SO THAT I CAN WIN THIS CHALLENGE?
THANKS IN ADVANCE.
PHOTOS FOR YOU TO LOOK AND GIVE OPINIONS.
https://lh6.googleusercontent.com/-m...907_204812.jpg
THE MOTOR THEY WILL USE IS THE CASTLE MAMBA 2200KV + MAMBA MONSTER, BUT THEIR CAR IS WAY HEAVIER THAN MINE.
TRAXXAS E-MAX SPECS
Additional Technical Specifications:
Length: 19.125" (486mm)
Height (overall): 10.5" (267mm)
Weight (fully loaded): 10 lbs. <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Wheelbase: 12" (305mm)
Front/Rear Track: 16.25" (414mm)
Center Ground Clearance: 4" (101mm)
Front and Rear Tires: 5.75" x 3"
Front and Rear Wheels: 5-Spoke 3.2"
Speed Control Type: EVX Forward/Reverse
Motor (electric): Dual 14V Titan™ 550, Fan Cooled
Gear Pitch: 32-Pitch
Differential Type: Hardened Steel Bevel Gear
Transmission: Driver-Shifted 2-Speed
Drive System: Shaft-Driven 4WD
Steering: Bellcrank
Chassis Type: Molded Composite Nylon Tub
Radio System: Traxxas TQ-3 (3-Channel)
Speed: 23+MPH (6-cell setup) 30MPH (7-cell setup)
