svt923
I tried quite a few different shocks combinations and I think the winner is going to be the Axial Yeti front shocks. The P-L SC Powerstroke fronts are shorter and obviously have less travel. The P-L SC Powerstroke rears are too long and in full droop, the Axial universals are clicking; this is with the shocks orientated in the mounts that would allow the shock to be at it's longest length (furthest out on the A-Arms and top inner mount on the DMG shocker tower).
The Axial Yeti front shocks are longer than the SC fronts, but shorter than the SC rears...perfect! I built the Axial shocks using Traxxas 2362 X-Rings so hopefully they won't be leaky. They are filled with Axial 30 wt fluid and I'm using the yellow springs; 14x54mm 4.33 lbs/in. I will likely order some Axial blue springs to try them out (4.95 lbs/in) too. If I stick with the Axial shocks, I'll order the aluminum caps and adjusting rings.
That is some good info about the front shocks Bil. Were those rear Powerstrokes a little too long or a lot too long? I have some shocks that are a few MMs shorter that I want to try on my truck but it looks like I may have to hit them with a few internal limiters.
