NorthwestYJ
use the search button! I would suggest you get Vanquish Products motor plates and or transmission cases.
Hey Man, I searched for an hour and finally found this again. Some people just don't understand how hard it is to find the info you are looking for.AS I STATED IN THE POST " OK ... i have searched and searched " I believe that indicates that I did indeed use the search button. "thumbsup"
Hey Man, I searched for an hour and finally found this again. Some people just don't understand how hard it is to find the info you are looking for.Anyhow, here is one thing I found and am in the process of doing myself. I hope this link works for you. http://www.rccrawler.com/forum/showpost.php?p=2721278&postcount=52
It's in ittybitty's build, about 4 or 5 pages in on the XR10 threads. I hope this helps, and the next time you need help I hope no one gives you any $hit about it.:evil: That is what a forum is for, to help one another! "thumbsup"Good luck with your build.
My idea of doing research is picking each others brain for ideas and what worked for you..8) I don't know how many times people told me the same thing they told you.. What a joke.. It is harder to be rude to people than just to answer someone's questions.."thumbsup"
Thanks for the link, I always use search as a first resort. I do try the advanced search and I am getting better. BUT a lot of time you just get so many hits back and after a day or two of trying differnt ways of entering the info I give up and ask. I have been a member sence I think 07 , not a nu be but deffinetley not a know it all. Like you stated some people just have to rise a feather or two for fun. Best just not to repsond and move on or give a quick answer or help. I read through a lot of these posts looking fo tid bits of info. And I do get a lot. THANKS!!
Would there be any room in this thread to put a little info about running the front axle case in the rear. I have been wanting to do this but I have not been able figure out what axle shafts I need for the rear now.
I always thought that the rear axle gear problems were caused by the seats of final gear bearings being oval and letting the bearings move up and down, making the mesh too loose.
At first I thought that maybe I just had a bad axle case or the case halves weren't tightened enough, but after swapping cases for new ones and tightening them down with care there was still the same slop.
The front axle final gear bearings are seated perfectly.
So I just "shimmed" the bottom of bearing seats with a couple of paper strips and had no gear problems after that.
Of course I still have to replace a few blown bearings after each comp, because I run stock everything.
FXR had capacitor in the bag, so just use it .
Get away from the dual ESC and just a Punk Dig Unit. Best thing I ever installed in mine besides the Mamba Max ESC. Just my opinion.
