Rig Rocker
Here's a good tip for bullet proof steering
Everyone has probably already changed their rod ends to 4mm revos, and that's what I used here too (Tra5347).
The steering drag link is 1/4" steel round stock, bent, drilled, and tapped to 4mm (Local Hardware Store)
My measurement after bends is 147.5mm - bare link end to end (Not eye to eye)
Measures 180mm eye to eye w/ bends and revo ends w/ V.P. Knuckles & Chubs (Same length for straight as well)
The servo link is made from a 4mm lunsford ti turnbuckle and traxxas jato rod ends (tra5525)
Link doesn't drag and barely hangs as you can see in pic. And I chose steel because it's not soft like aluminum and will slide over rocks easily
