Axial XR10 Tips & Tricks
.60 lexan electronics tray.
I may press a small channel between the links for more battery support after a little testing tonite.
the screws for the links
When installing the Machined lower links, be sure that you use AXA186 M3x16mm set screws. The AXA187 M3x20mm set screws are too long as pictured below.
Do u have to order more to do this or does the kit have the xtras in it??? i did order the high clearance links and would like to know if i need to order those screws also!! thanks
Nope, the kit will have all the 16mm AXA186 set screws you need "thumbsup"
Thanks i cant wait to get this in!! Stupid me forgot to order my blue round bent links lol out of everything i ordered!!! oh well only 30 more bucks to put on the credit card yay!!! ;)
I just updated my first post with this info:
Another VERY important thing not to miss during the build is the installation of the rear axle plate (AX30559). Without this plate installed with the correct hardware the main support of the 5x8 bearing for the final gears is compromised. Immediate failure of the gears will occur without the hardware and rear axle plate installed! Please dont skip this step "thumbsup"
yes it does look like those screws do need to be there!! i was wondering if anybody is running the mamba max with punk dig how well this setup fits inside this chassis??
Kinda lame one but, if you get some strc middle or 2/3 30 deg. Bent links for the war, it will push the wheelbase to 12.5 and you can slide the stock plastic covers over the links, bend and all, to keep it slippery!
i was looking at this myself just to keep my links from getting all scratched :lmao: but no i like the idea cause alum does hang up sometimes!! "thumbsup"
Another step 23 tip
Pay close attention to the order of the screws used when mounting the rear axle plate (AX30559)!!!
You must use screw AXA465 in the specified location. If you use a screw that is any longer, the screw will protrude into the axle housing and the 5x8 bearing for the final gear will not be able to seat in all the way.
You can see the hole where the screw came into the bearing seat in this picture:
just means ill have to be sober if i ever take it apart lol may put the wrong one in there "thumbsup"
Titanium Bent Lower Links
I have found that 4mm Revo rod ends on lower links are almost bullet proof.
For the lower links I am using Lunsford TI rock grinders.
The fronts are 125mm with a 30* bend in the front to accommodate the horizontal link mount unique to the front axle. They are bent 30*+ at the main bend. (The rod end that mounts to the axle had to be shaved a little to fit.) Total i2i = 137mm
The rears are 130mm bent 45* at the main bend. I also added the 30* lower bend here as well so it ramps up at the motor better. Total i2i = 137mm
Wheelbase is exactly 12.5" measured per USRCCA rules.
I also made a new electronics tray to get everything as low as possible.
I had to grind my electronic tray a little more due to the extreme bend in the rear links pushing them up further.
I really like the stance and it's breaking over things it was hanging up on with ease now.
