svt_adam
I set my axles up with the stock gears and VP trans cases and motor plates do I need to replace the bearing in the link mount as well? Or should I replace the link mounts with VP parts as well?
ok thanks i will look thereYou can try Golden Horizon... Their parts aren't the best, but they do offer a metal servo mount that seems to work pretty well.
If you strip out your wheels bead lock screws 4-40 X 1 1/4 stainless steel counter sunk screws work great
If the wheels are new and have never had a screw in them, will the 4-40's thread in easily and is 1" in length long enough (24.5mm=1.0")?
How would i know if i should get a straight or bent vanquish steering drag link for the XR10?
Hello Guys, Are there any place i can still get a XR10 kit ?
