Hhmmm... I’ll have to give that a try and hopefully it straightens things out
Adjusted my front shocks again yesterday as the front was raked forward & ran into the same issue lifting the front axle. Pan hard bar was pulling my suspension left this time.
Didn’t wanna fiddle around looking for a link that was about 5-7mm longer, so I ended up backing out both of the eye holes, or whatever they’re called, & it gave me the length I needed to straighten the axle back out to center.
You can try that out & see if that works for you to straighten the axle back to center. I get a little bump steer due to it being DIY’d, but it’s only very minor.
It’s only a temporary solution until you can find the right length you need. There’s a seller on eBay, RC Issues Inc, that makes wheelbase aluminum or brass links but also makes custom length ones too. All he needs is the length from eye to eye & he’ll make you a set. If you know how to cut, drill & tap your own links, then you can do it on your own with some aluminum rod.
Hope this helps.
