any crawlers in MN?
im not really sure if ill have my wk done by the first comp. it willbe close but not quite. can i run it almost done then finish it in between. probely won't have it done because my spur gear, rod ends, and my driveshafts are all on back order.
Let me guess, Tower?
Can't get a ride to Jerry's?
yep tower. i consiterd going to jerry but there allready on order. if i don't have em by aug 2nd. im going up there. because what i need to start the build i don't have. or i have and i need the other half to make it.
HEEEEEEEEEEEEEEELOOOOOOOOOOOOOOOOOOO IN THERE?!????
ISis THEREthere ANYanyONEone ALIVEalive INin HEEEEEEEEEEEERE
eeeeeeeeeeeeer eeeeeeeeeeeer eeeeeeeeeeer
well my wheely king officially has a locked rear end, and mashers. soon to come will be spur/pinion, lengthened wheelbase, locked front. this truck is great stock ! i will more then likely have it done by the first comp. but if not the only thing i won't have will be a spur gear (still on backorder).
Hey Joe,
"Where you going with that gun in your hand" Jimi Hendricks
Joe we haven't met I don't believe, my name is Norm but I have been called Stormin for about 30 years. My son in law and myself are new members of MNRCRC.
Sounds like you'll have your WK ready for the August 12th comp. We have a special guest from Crawlerado coming to compete. You may know him as Slugz, he is seen often on these pages RCC as part of that infamous "Crawlerado Gang".
So put the hammer down on that WK and hopefully we'll see you on the 12th "thumbsup"
Stormin'
If all you need is a spur gear, I'm sure someone can hook you up. That's something that could easily be installed in the parking lot. I'd hate to see anyone miss a comp do to such a simple piece. Keep us posted.
niec to kinda sorta meet you stormin. it's a 48 pitch 96 tooth.if you don't have it i can run stock gears. i brought it with me to the 1:1 event in chetck and it's crawling great. tonite i need to extend the wheelbase and lock the front. anyone have a batt. i can barrow for the comp. the one that came with my wk won't take a charge from anything and my other batt. has horrible run time.
I think its 12-7, Monday, Tuesday, Thursday, Friday, and Saturday is 10-5? You should have looked at his hours sign while you were there :)
