Truck did good with foams removed but as expected and others have found, tires would roll over too much on side slopes. I cut the stock foams in a star pattern as most do but thought they stiffened the tire up a little too much, so I cut the stars off. The result is like a foam run flat insert I guess. No resistance til about half way flat, but the foam seems to keep the sidewalls supported and help against them rolling over. Worked real good.
Ordered a Hexfly HX-N802 2A Battery Charger so we can charge the stock 2000mah batteries in around an hour hopefully. Also ordered an Axial SCX10 lift kit / droop kit. Hoping it will allow the shocks to be mounted more upright. My youngest boys basher driving style and shaved steering stops has caught up with him and broke a knuckle mount. I knew it would at some point though.
What's the best all around tire for this truck, for mostly rock, but with dirt / trail riding not compromised? We don't run them in mud. TSL's, Boggers?
