Rcbroncoguy
what did your wheelbase turn out to be??That's a great idea, don't know why I didn't try that yet. I played with the links for a long time trying different setups too.
I did this to mine. Turned it into a scaler.That is sweet. I might do that with mine. I was also wondering if have an axial chassis, would there be any benefit of switching to it over the redcat cradle?
Sent from my ASUS_Z012DC using Tapatalk
please post pics of final product. was looking at these exact same ones, was also wondering how they going to work with my rear lockouts
All they aare wheel hex extentions. They fit over your hex and the barrel nut goes through your wheel and extention to thread on to the axle shafts. So there shouldn't be a problem with your lockouts. Only problem there could be is the wheel center isn't big enough for the barrel nut. Which you could drill that out so it fits.
A winch is more of a scale item for a scaler type rig which the e10 in Stock form is not. However, if you're wanting to build a scaler with it, I would say buy or manufacture a ladder type chassis, buy or manufacture a bumper to mount on it, and mount your winch to that. If you're wanting to keep the vertical plate chassis, I would say you could probably manufacture some type of crossmember in the chassis to mount the bumper to and run the line out through the front of the body.Hey everyone I just picked up a e10 and was wondering if anyone knows where is a good place to mount and winch?
thanks
Links and shocks are bolt up. Axle parts take a little modification but easy bolt up. Chassis both scale and comp. Trans with a redrill of two skid holes. I ve read metal trans gears work in stock trans but need to swap to axial outputs.
This thread has just about covered everything. Read every post.Has anyone made a list or thread of what axial parts are direct bolt on or minor modification to fit?
