if you go with 3s it is highly suggested to use a bec to power the receiver.
try to get one with adjustable voltage so you an set the voltage up to around 7 volts.
be sure to check the specs for the servo you are using.
3300 mah is a hefty battery, for comparison, the comp guys use 600 or 800 mah lipos
and they last 20-30 minutes but they are mostly concerned with weight and placement.
I use 3000 mah nano-tech, it is a bit shorter than a nimh pack and about 2/3 the thickness
Beelzebub, nice shiny metal frame and other parts are very pretty. your words are you are just getting back and
there are a lot of ways to go. take it slow until you come to grips with what direction you want to go.
whether it is crawling or building a scalar, what kinds of terrain you want to play in, how fast you want to go.
most of us end up with more than one rig ( many more it seems haha). the Everest has the benefit of being a clone
so there are many options, that HG P401 is small - wheelbase is 10 - 11" x 8". it does look cute, just about
any spares will have to come from china even though some of the cars are available to be shipped from usa.
buying metal upgrades mostly accomplishes making the rig heavier and your wallet lighter.
wait until you see what is being done, look through build threads including axial sc10 and ax10, look at moas and
the full blown crawlers.
you will spend money, best wait until it will be worth it, not on cheap parts just to look shiny
