I can't seem to find any that will ship to the US. Think I'm gonna do scx10 ones.
Hubs are very easy to find but the knuckles seemed to be hard to find on ebay.
I was coming back down a decent sized hill with some big ledges. Rolled off the first one and bounced 4-5 times before it made it to the bottom. It wasn't fully broken until I didn't realize it was broke and dove it.I've had mine for 2 years driven by my son for those 2 years and the only thing he broke was a c hub from launching it off the end of the slide. The slide was 6 foot high and had a 1 foot drop at the end. It was lucky to only break that. I did strip a spur and pinion slso. Caused actually not by the spur but the oinion. Being brass they wear very fast then it started damaging the spur. Personally I think leave the spur plastic and replace the pinion with steel. A steel spur will just destroy your pinion. I learnt this the hard way on my scx10.
In 2 years of driving the Everest did you ever have to replace anything other than the pinion (and the spur it damaged), like the driveshafts? I'm assuming that you were running Axial iron cross lockers in your diffs, or were "lucky" enough to receive an E10 with upgraded metal lockers?I've had mine for 2 years driven by my son for those 2 years and the only thing he broke was a c hub from launching it off the end of the slide. The slide was 6 foot high and had a 1 foot drop at the end. It was lucky to only break that. I did strip a spur and pinion slso. Caused actually not by the spur but the oinion. Being brass they wear very fast then it started damaging the spur. Personally I think leave the spur plastic and replace the pinion with steel. A steel spur will just destroy your pinion. I learnt this the hard way on my scx10.
I fitted 3racing lockers and stupidly filed the locker cus it was soft aluminium instead of filing the axle shafts. So the lockers slowly started to widen up but never got to the point of slipping. Never broke an axle shaft. I have since replaced the axle housings with axial units. Fitted the HSP/E10 diffs into them with iron cross lockers and scx10 shafts front and stock hsp outdrive cups/axles. Fitted scx10 rear shafts and lockouts on the back. Old shafts had nothing wrong with them. Just fitted scx10 cus I had them spare. I only did all that because he broke a c hub and I had all the bits there. Plus the scx10 units slide over rocks better/easier. The car is 90% scx10 now anyway. All HSP gear was mounted to an scx10 chassis. Now only the diffs and gearbox are HSP.In 2 years of driving the Everest did you ever have to replace anything other than the pinion (and the spur it damaged), like the driveshafts? I'm assuming that you were running Axial iron cross lockers in your diffs, or were "lucky" enough to receive an E10 with upgraded metal lockers?
The stock unit is lipo ready just does not have a lipo cutoff. Can just be used with a lipo low voltage alarm.I ordered an e10 for my girlfriend and hers came with a lipo ready ESC. Wonder how often there are units with upgrades installed from the factory?
