Recieved the HR hubs and knuckles today. Great looking pieces...
But ran into a snag on install. You have to reuse your spacer sleeve from the stock knuckle. When I went to tighten down the knuckle to hub it would bind like crazy. Ended up having to add 1 shim inbetween the hub and knuckle. Did'nt matter if it was put on the top or bottom side. After that it was silky smooth.
Also started the truss installs. Got the rear finished but have a question on the fronts. The supplied button head screw holding the link stay on pushes the truss away from the axle housing. I'm wondering which way you guys are mounting the truss? Obviously your own supplied spacers are needed for the rears and fronts as well ,but are you guys spacing the truss far enough away from the axle for the button head screw clearance, countersinking the truss, or drilling a hole through the axle housing?
Or some other way I'm not thinking of?
I'm going to countersink the truss unless I hear of a better way of doing it before I install it tomorrow. I figure countersunk keeps from needing a spacer at the hub and keeps the truss closer to the axle for support.
Pic of what I'm talking about and am going to countersink.
Sent from my iPhone 4 using Tapatalk
