28offroader
TT is mainly link geometry...you have the rear set up well enough but you also need to seperate the front uppers...move them to the outside of the link tabs on the axle...15mm worth of spacer/s will be needed between the tabs or two rod end balls. Heres the problem...the front axle roll center is still too close to the front axle. Also your shocks need to angle outward from the chassis to the axle mounting points...not like stock but a little. Having them so far apart at the top and almost equally spread at the axle/s makes for less outward spring response. My front shocks are almost straight up and down from the chassis to the axle but my front upper links are spread apart.
How much weight are you currently running in your front wheels? You need at least 3-4oz to help the front end settle the spring pre-loads.
Cool, I'll move the front links and see what I can do to the shocks. I do plan on moving the shocks like yours inside of the chassis for better steering.
No weight yet in any of the wheels. I plan on getting some this weekend though. I'll go with 4 in fronts to start with. Thanks..
