Mike Flea
Try using a lower turn motor, or changing the spur/pinion for more wheelspeed?
yeah... gonna mess with the gearing a little... if I canTry using a lower turn motor, or changing the spur/pinion for more wheelspeed?
Did you do a write up on any of this ? pics ?If you got to big of motor
you have to modify the mounting holes in motor plate
plus you have shave the transmission with a Dremel, got high speed cutters and basically carved and shaved the tranny
Its not as simple as dropping in a motor
I got a 270 brushed motor in one
and a 380 18.5T brushless motor
and both of I had to shave the transmissions and modify the mounting holes to get 2 screws in it and too the gear mesh just right
cause the spur gears are oblong and got high spot, both of my Exceeds are that way
cause when I got my used one the guy only had one screw holding the 270 motor in and the motor would twist and loosen up and I was smart enough to stop and not strip a gear
so I made my own motor mount plate, but the 2mm screws stripped out my holes that hold it to the tranny and it won't work
so I could make 2 more motor plates and get some better spur gears
it took me awhile and a lot fitting and shaving and fitting and shaving until, I got it too work
I have not found Pinions or spur gears to change the gearing
so if you find some, that will work and are not oblong or got high spots
please let me know cause
I want to play with the gearing a little too
cause I would like a spur gears with out high spots please
Taco
Here are some pictures
you can see a little of where I shaved it
I had to do the same to both of them
and I also had to open up the center on both motor plates
and open up the holes for the motor
oh quit with yer little girl whining...I pulled tranny so you could see
since I only type bullshit
that you don't even ****ing read
have a nice day
I may look for some shorter, better quality shocks later.I was a little leery about it at first, but now that Joe is sitting on it, it doesn't look that bad. The body still seems to sit a bit high, (lot's of space between fenders and tires), but not knowing how it's going to run either.
I know you put those extensions on there to straighten the shocks up, but how about trying a set of shorter shocks, might lower your COG a little.
yep... no fire under muh butt, 5 day, no china fo' me.Where do you order
parts from China
and they delivery them by Canoe
pay for the faster shipping
you cheap bastard
...they can be anyways I likeand why are you shocks
tipped in towards the frame
should they not be straight up and down and not tipped in cause the bottom ball is not straight
