TacoCrawler
inside muh head
The wider that the shock(s) mount on the axle...
the more stable and planted the chassis will be.
But extreme articulation/max flex may be sacrificed slightly.
But I'm going for a scale/realistic flex-articulation here...
not some super crawling spider monkey thang.
Obviously the tires cannot rub on the shocks when turning.
So spaced too wide... and there's other problems.
Tho' mine currently clear at full L/R steering lock. ~just barely~
Maybe it's the offset/backspacing of these particular wheels...
or the slw hubs used that gives more room.
~Don't know, Don't care~
Imma change out to 6" tires (or near that)... eventually
so fit will get more crucial on that day.
So the option of changing the shock position(s)
may come in handy one day. ;-)
I had to move the lower shock mounts outboard of the lower mounts...
so that I can share the lower mounting ear(s)/bolt with the susp. link.
As well clear the lower shock bucket - upper ear (mount)
This shock placement nets me the lowest possible
chassis ride height.
So I'll start here... and change it if necessary.
The upper eye/ear of the mount is left unused... (for now)
and it could simply be cut off if one wished to.
But the upper hole on the lower mount is originally designated for the shock(s) lower mounting position.
And I'm keeping those intact for further ride height adjustments if I need.
I'm not following any instructions... I'm doing my own thang
even then... I'm all about reliability and durability...
so the lower mount(s) upper tabs were reinforced by putting a bolt W spacer thru/in between the ears.
Granted I went a little wide originally...
but it had more to do with my bolt length availability,
at the time, then anything else.
I'll be changing out to shorter length bolts...
when I pick those up.
Prolly some better looking alloy spacers as well
once I determine the exact length needed.
The bottom of the shocks will still be spaced outboard slightly wider
then at the uppers.
But both will be moved inboard equally in their distance.
I do this for a purpose.
as it will push the axle downward as well as outward slightly...
creating some resistance during higher speeds and turning.
The body and the chassis should roll flatter.
well... in principle anyways.
it's kinda like the principle utilized on ifs cars...
a little negative camber added...
and it corners a little better.
Only ya can't change camber on a SA
so I'll try for similar result...
using force/resistance instead of neg. camber.
kool thang is...
...nothing is, forever
so being able to easily return it back it's original state
as a stock Wraith, is one of my goals.
then at the uppers.
kool thang is...
