Hey watch your tone
the Exceed links are just a little bigger than a 3mm set screw
and they don't sell links that small
and I don't know how to make longer links cause,
and if I had the right longer links, and if cut them to fit, I can't drill and tap them
cause I can't find all thread that small and it would bend pretty easy, even if I put tubing over the threads
too thread into the 2 mm rod ends and I don't want to have glue them in
so I need to look online and see
what links I can find
and if I add 3mm nuts it shortens the threads on the set screws, that thread into the links
I will look at Axial they have threaded links in different lengths but there 6mm and maybe too thick
I need to check it out
when you get your Everest
take a look at look and you will see
what I mean
what I mean
