TacoCrawler
welp... these showed up today "thumbsup"
edit: 12-14-16
I installed four of these on my SCX-10
replacing my plastic bodied Traxxas Ultra XL BB shocks (1st gen T-Maxx)
My tires now stuff upwards abouts 4mm more...
'cause the alloy XXL BB bodies are near 4mm shorter then the Ultra bodies.
I'll Likely need put a rubber limiter on the shaft
to reduce my body's rub and the shock(s) compression a lil' bit.
Or maybe just do a little body trimming /or shorter tires ;-)
BigBore ? the TRA 4862 XXL Alloy big bore shocks
have a smaller body diameter and hold less oil volume then do my Ultra XL BB's :???:
Good news is Axial wraith coil springs fit these XXL's perfectly.
The Ultra XL BB shock bodies have a replaceable thread on shaft seal cartridge/cap.
Whereas the XXL's have a lower circlip holding the seals/Orings in place.
The Ultra's seal cap/cartridge was easier if need be... have held up fine for me.
The XXL BB's are silky smooth without doubt 8)
The hard/teflon coated alloy bodies and nitride coated shafts
ensure the shaft's seal well in the Oring shim stack.
They really make for a higher quality precision/performing shock IMO.
I like my Utra XL BB's plenty and they've always worked fine and have never leaked/failed from my use.
But the alloy bodied XXL BB's really are nice if one is looking for an alloy bodied shock. "thumbsup"
~ hoping I don't have to repack the Orings/shims anytime soon ~
The remaining four will be going on my 1:6 TJ :|
edit: 12-14-16
