Mike Flea
Your spare tire mounted in the middle of the body will warrant a longer lunette to keep from hitting the spare. Mine was mounted more to the right side of the rear body, so while I had clearance to the left 90 degrees, I only had 45 degrees to the right, if Jeep and trailer were on level ground.
If I had left the spare mounted to the rollbar, I would have had 90 degree to jackknife in both directions in reverse.
On your Toy above, you have clearance all around because the spare is in the bed.
