The electronics I removed from my VS4-10 Ultra are some spaghetti wire for sure. And there aren't that many places on the Fordcye to put a big ESC like the Mamba X especially with the BEC stuck to the side. The real estate is small in RTR form. Nothing turns girls away like bumpy (Fordyce) and small!
This may be the first time I ever moved a truck to the side because I didn't want to deal with the electronics! Time to get back to it as I want to get this truck back out on the trails.
Who's hungry for some wires?
First up, I removed the unused servo mount. I think this is for the DIG option. I didn't take many photos unfortunately. When the servo mount is removed, the side trays are left with standoffs. No idea why the parts were designed this way. Would have been cleaner to include the entire standoff with the servo mount and upon removal, you would have been left with a clean side tray. That wasn't the case, so I removed the side tray and cut off the standoffs.
Look how much frickin' room you gain by removing the servo mount and the gargantuan battery tray. The stock battery tray sits way high. I think this is mostly because it mounts to the panel above the rear axle.
Does anybody know the intended use for the grooves in the battery tray as indicated by the red question mark (?) in the image below? My guess is wire management, but I don't think I ever used this in any of my Vanquish builds.
My current plan is to trim off the yellow parts of the battery tray. I don't see why it needs to be tied to the rear chassis plate crossmember. I can then shorten the standoffs on the battery of the stock tray and lower it way down. I'll also remove the two wire management clips with the yellow box around them.
The better and more final solution is to design and print a better battery tray. That includes one for the side slider top plate. If you guys know of any existing designs that will work, please let me know. I want to run at least 2200 mAh batteries in this rig so I don't want the center tray that I used on my VRD Carbon.
