Portal Axle build
I want set based on the new ar44 gears and under/overdrive gears. That will be just awesome with much better ground clearance!!
I will support the Kickstarter for sure either way.
Thanks Johan! We would also like to be able to use those gears. Once we can get our hands on them, I can start to model a housing around those gears.
Any thoughts on doing a set of axles that are narrow enough to fit under the Tamiya Midnight Pumpkin/MF01X bodies?
It might be possible to do a more narrow set for those bodies but there is a built in limitation because of the portals on the front axle. We can explore the options though.
Any idea when these will be available ?
We hope to get the Kickstarter going this month but Tedd any myself are quite busy and aren't even in the same country right now. Once we get the quotes back form the injection moulding factory and get a time together to make a video then we will launch the campaign. We WILL tell anyone that will listen about it "thumbsup"
I need these in the worst way ........would be perfect for my pinzgauer build and also my unimog build
We totally agree!
X2.... "thumbsup"
X3!
All of the axle sets have been sent out with all of the updated parts so we should start to see the pictures of the builds trickling out onto the Internet.
Thanks for your continued support!
- Chris
