BobTeagle
Flexible plastic would cause the gears to bind and wear prematurely. The rear diff cover on my Baja Rey is actually quite stiff; I think the problem is simply that the bearings are too small to handle the load.
I'm content to use a plastic axle. It's lighter, so there's less unsprung weight, which means the rear suspension will actually do its job properly. It just needs larger bearings, that's all. Dlux Fab modifies stock AR60 axles to accept 5x13mm inner pinion bearings, and they work great; maybe we can talk them into doing the same with Baja Rey front diff cases and rear diff covers.
I see where you are coming from. I agree larger bearings would have to help. The rear end of the Rey would be an easy mod since that piece tha holds the bearings is so small.
But I have both the yeti rock racer kit and the yeti score kit. I used fast Eddy bearings from day one on both. I used the same motor / esc in both. I put a ton of aluminum into the rock racer which made It much heavier than my score. In the rock racer I used a boom racing alluminum rear axle which uses stock sized bearings and it's still going strong. On my Score I used the stock AR60 axle and it blew this same bearing three times. All this happened without any premature gear wear. I know this all happened with Axial not Losi, but the bearing size didn't matter. The same fast Eddy bearings held up on a heavier vehicle which took more stress but had the alloy axle to hold the bearing firmly in place.
Just explaining where my logic came from. I may be wrong, but that's what happened to me. The good news is the Losi is holding up much better as I have only blown one bearing. I too replaced mine with Boca ceramic bearings in the rear. That has worked so far
