BobTeagle
Agreed that out of the box it handles a ton better and the center diff certainly helps in the regard but with some tuning the yeti can run pretty close to the Rey, maybe not quite as fast top speed but very close.
Actually if you change out the spur on the yeti score to the optional 56t and run 20-22t pinion you can get the same speeds as the Baja Rey! I was running the 56t spur and 22t pinion with a 3100kv motor on 3s and getting speeds well over 40mph! This gearing was still conservative for the motor and esc I'm using, temps were reasonable! After tuning my Score I feel it only needs a center diff to perform like the Baja Rey! I'm still hoping Axial or aftermarket offers one. The small final gear in the transfer case could be swapped out for a center diff. It would be small but would be fine if made with hardened spider and sun gears!
I still give a nod to the Baja Rey for its out of box performance! When aftermarket parts kick in with more tuning options it's really going to be limitless! A carbon fiber steering rack to tighten up the front end is first on my list. No more darting left or right under hard acceleration..
