ScaleFreak93
Will definitely do "thumbsup"
When they are available you should try a gen3 with the ar44 lockers, gears, and unis that come on the scx10 2.0.
You have my interest, these would look right at home under my hardbody G63 6x6 I'm building.
Nice work!
-Derek
Any plans for 3 link and panhard mount?
Following along here, and also designing my own portals.
In regards to OD/UD, it really isn't that complicated assuming gear availability isn't an issue. For instance, you stated that you're using 11t and 23t 32p gears...11t being the smallest you'd most likely want to use for ideal tooth contact...you could design the upper gear pocket to fit a 12t, then a 22t can be used in the lower position, giving you an OD option simply by swapping a few gears, which would still use the same center-center distance.
May not be what you're after, but worth a second thought.
23/11=2.1:1
22/12=1.83:1
