Tzicul
Ok, it seems it's working now, but only when no icon is highlighted on the screen (model, name,...). Is this normal?
The end points are set separately from assigning the switch. I'm not sure how that screwed something up?
Hi I'm just getting back into rc after about a year break and cannot for the life of me remeber how to adjust settings on your hacked rx could you please link the instruction manual
I assigned it to dual rate slider, but not sure on how to go about setting these endpoints.
Need some help here. Attempts to intall the hack on my GT3C have failed. I followed instructions. Loaded gt3b-0.6.1.s19 and to program then current tab. Put lipo in and turned on. From there it never said CAL or allowed me to set voltage. Now the menu to all weird and when I turn it on it turns on to Model No 0 M50%. I've repeated the procedure several times and nothing seems to change.
Got it thanksYou're on Model 50.
Power up, press enter, scroll to model, press enter, scroll to No 0 M00%, press enter, press back/end afew times. Now you're back to model 0
Now to calibrate start watching here.
https://youtu.be/fdy64fUNvJk?t=57m29s
Quick repeat of the question...does the GT3B or GT3C output the 8 channels on ppm? For potential use with an LRS module? Thanks!
