the ZL1 Camaro is coming back! after 40+ years
STANG KILLA SS
~THE SCALE SHOP~
KILLEEN TX
:shock:
the short:
2012 CAMARO ZL1
6.2L Supercharged V8 LSA
6 Speed Manual Transmission
Heavy Duty Driveline
Magnetic Ride Control
Brembo Brakes
Electric Power Steering
Track Ready Cooling Systems
Aggressive bodywork, including vented hood, Transformers 3 style bumper, special wheels
New steering wheel and interior trim with silver accents throughout
the long:
After much hoopla has been made over the mysterious "HP edition" Camaro, GM has finally let the cat out of the bag. This car isn't named HP Edition or Z28, it's officially the Camaro ZL1 and it is a beast.
As expected the car is powered by GM's supercharged 6.2-liter LSA V-8, the same engine in the Cadillac CTS-V. The engine produces 550 horsepower and 550 pound-feet of torque.
Perhaps a bit less expected is the aggressive performance enhancements the ZL1 has over the more 'regular' Camaro models. GM states the car has a beefed up drivetrain and track-ready cooling system, among many other changes.
■LSA 6.2L supercharged engine will produce an estimated 550 horsepower (410 kW) and is matched with a six-speed manual transmission with a dual-disc clutch system
■Packed with performance technologies, highlighted by Magnetic Ride Control, and advanced materials – including a vented carbon fiber hood insert. Extensive aerodynamic development designed for high-performance driving
Motivated by a supercharged V-8 engine producing an estimated 550 horsepower (410 kW), the Camaro ZL1 will be the fastest Camaro ever offered by Chevrolet. And more than just power, the ZL1 features technologically advanced and highly developed chassis and suspension systems that help it deliver balanced, track-ready handling and braking power to complement its high engine output. Rigorous development of the ZL1 is ongoing, and official estimates of the car’s capabilities will be released later in 2011, as testing nears completion.
The ZL1 name is derived from the all-aluminum racing engine of the same name, which was developed in the late 1960s and installed into a handful of regular-production 1969 Camaros. Only 69 were built with the engine, but they’ve achieved mythical status among enthusiasts, as they represented the pinnacle in Camaro performance – until now. The 2012 ZL1 model is designed to be a major leap forward for the Camaro, bringing a new level of performance capability to the segment.
Major elements of the ZL1’s design are a new front fascia and hood with air extractors, designed in tandem to create aerodynamic downforce to aid handling. The car’s hood includes a signature center section constructed of carbon fiber and rendered in satin black finish. New rocker panels, wide tires, 20-inch wheels and exhaust tips portray the car’s handling and power.
The ZL1 badge appears on the grille, hood and the brake calipers, all key areas portraying the technology within.
Tech overview
Supporting the dynamic track and street performance of the ZL1 is the LSA 6.2L supercharged engine, which will produce an estimated 550 horsepower (410kW) and 550 lb.-ft. of torque (677 Nm), with specific features for the Camaro. Built on GM’s legendary all-aluminum, small-block V-8 architecture, the LSA features an intercooled supercharger system, premium heat-resistant aluminum-alloy cylinder heads and other details designed to ensure its exceptional performance is delivered with smoothness and refinement. Components and design elements that contribute to the LSA’s performance include:
■Balanced, lightweight reciprocating assembly
■High-strength hypereutectic pistons
■Sixth-generation Eaton supercharger with four-lobe rotors
■Piston oil squirters.
Because the Camaro ZL1 uses electric power steering, the engine does not incorporate a conventional hydraulic power steering pump on its accessory drive system. This enhances performance, because no engine power is used to turn a steering pump pulley.
Transmission – The high-performance Tremec TR-6060 six-speed manual is matched with the LSA engine. It is the “MG9” version of the transmission, with a higher torque capacity. It is used with a dual-mass flywheel and twin-disc clutch for easy operation and shift smoothness. A new, shorter-throw shifter actuates the gear changes.
Exhaust – ZL1 is equipped with a dual-mode exhaust system, which alters the sound level and character in response to engine rpm. First used on the legendary Corvette, and specifically tuned for Camaro ZL1, the dual-mode exhaust will give the car a signature sound.
Drivetrain – It is revised with a stronger driveshaft and rear axle system, featuring a larger and stronger cast iron differential housing, stronger axles and heavy-duty limited-slip differential. This patent-pending system is designed to ensure that ZL1’s tremendous power is delivered smoothly to the ground.
Suspension – The suspension features completely revised tuning and the inclusion of segment-exclusive Magnetic Ride Control. ZL1’s Magnetic Ride system will include driver selectable modes (Tour and Sport) tailored for the preferred style of driving. It uses advanced magneto-rheological science to produce shock damping with the highest level of precision, enabling body control optimized for excellent performance in everyday driving as well as track situations. This technology appears on only a small roster of some of the world’s finest performance cars. Other chassis elements are redesigned to support the car’s high-performance limits. Rear stabilizer bars have drop links repositioned outboard of the control arms. This makes the bars more effective in controlling body roll in turns, with crisp response to driver commands.
Brakes and Steering – Camaro ZL1 features an advanced track-capable braking system, developed in conjunction with experts from Brembo. The large 14.6-inch (370 mm) two-piece front rotors have six-piston calipers; the 14.4-inch (365 mm) rear rotors have four-piston calipers. ZL1 marks the entry of a new electric power steering system to Camaro. It is being developed to ensure precise control and feedback to the driver, with greater variability of effort for high-performance driving.
Exterior – ZL1’s signature from the front is the redesigned fascia and aluminum hood with a raised, carbon fiber insert. The fascia includes a front splitter and new vertical fog lamps. The fog lamp area includes air intakes designed for brake cooling. The hood features front-mounted air extractors that direct air precisely over the car. Visually, this center section, in satin black carbon fiber, communicates the car’s high-performance intent as a visual contrast to the car’s exterior color. Functionally, the air extractor is a key in connecting airflow closely to the bodywork, creating aerodynamic downforce. The carbon fiber center section reduces the mass of the hood. High-intensity discharge (HID) headlamps and fog lamps are standard. The rear of the car includes a diffuser and spoiler, also functional elements that enhance the car’s aerodynamics.
Wheels and Tires – New-design, 20-inch forged aluminum wheels, which are lighter than the 20-inch wheels used on the Camaro SS, are used with new Goodyear Supercar F2 ties developed specifically for the ZL1.
Interior – ZL1 is tailored for high-performance driving. The front seats feature microfiber suede inserts. Other enhancements include a redesigned steering wheel, alloy pedals, Head-Up Display with unique performance readouts and the “four-pack” auxiliary gauge system featuring a boost readout.
Production details
All of the Camaro exterior colors will be offered with the ZL1, but black is the only interior color. The unique exterior features are complemented with a black center section on the hood. Inside, the Camaro ZL1 has heated leather seats with microfiber inserts and ZL1 logos embroidered on the front headrests. Microfiber suede is repeated as an accent on the instrument panel, adding a richer look to the interior. The ZL1 will include the same content as the current 2SS package and include the following new or unique features:
■Six-way power driver and passenger seats
■Unique instrument panel and door panel inserts; and ZL1-logo sill plates
■Steering wheel audio controls with Bluetooth capability
■Wireless PDIM and USB-port
■Boston Acoustics premium audio system
■Rear parking assist
■Rear camera system (displayed in the inside rearview mirror).
Engineers have already driven Camaro ZL1 prototypes extensively at demanding road courses in the U.S. and Germany, with final testing being completed through the balance of 2011.
About Chevrolet
Founded in Detroit in 1911, Chevrolet celebrates its centennial as a global automotive brand with annual sales of about 4.25 million vehicles in more than 140 countries. Chevrolet provides consumers with fuel-efficient, safe and reliable vehicles that deliver high quality, expressive design, spirited performance and value. The Chevrolet portfolio includes iconic performance cars such as Corvette and Camaro; dependable, long-lasting pickups and SUVs such as Silverado and Suburban; and award-winning passenger cars and crossovers such as Spark, Cruze, Malibu, Equinox and Traverse. Chevrolet also offers “gas-friendly to gas-free" solutions including Cruze Eco and Volt. Cruze Eco offers 42 mpg highway while Volt offers 35 miles of electric, gasoline-free driving and an additional 344 miles of extended range. Most new Chevrolet models offer OnStar safety, security and convenience technologies including OnStar Hands-Free Calling, Automatic Crash Response and Stolen Vehicle Slowdown. More information regarding Chevrolet models can be found at www.chevrolet.com
PRELIMINARY SPECIFICATIONS
Overview
Model: Chevrolet Camaro ZL1
Engines
LSA 6.2L Supercharged V-8
Displacement (cu in / cc):
376 / 6162
Bore & stroke (in / mm):
4.06 / 103.25 x 3.62 / 92 mm
Block material:
cast aluminum
Cylinder head material:
cast aluminum
Valvetrain:
overhead valve, two valves per cylinder
Fuel delivery:
1.9L supercharger with intercooler; sequential fuel injection
Compression ratio:
9.1:1
Horsepower (hp / kW @ rpm):
550 / 410 @ 6100 (estimated)
Torque (lb-ft / Nm @ rpm):
550 / 745 @ 3800 (estimated)
Maximum engine speed (rpm):
6200
Transmission
Tremec TR6060 six-speed manual
Final drive ratio:
3.73
Chassis / Suspension
Front: double-ball-joint, multi-link strut; direct-acting stabilizer bar; progressive-rate coil springs; with Magnetic Ride Control
Rear:
4.5-link independent; progressive-rate coil springs over shocks; stabilizer bar; with Magnetic Ride Control
Brakes
Type: four-wheel disc w/ ABS; ventilated two-piece front and one-piece rear rotors; six-piston fixed Brembo aluminum front and four-piston rear calipers
Rotor diameter, front (in / mm):
14.6 / 370
Rotor diameter, rear (in / mm):
14.4 / 365
Wheels / Tires
Wheel size and type: 20 x 8-inch aluminum (front)
20 x 9-inch aluminum (rear)
Yah know, muscle cars used to be cheap... now they are $35k+. Saddens me greatly.
The '69 ZL1 Camaro had a sticker price of about $7200.
$7,200.00 in 1969 had the same buying power as $43,798.11 in 2010:shock:
I guess you get what you pay for:ror:
Old news but Im still stoked. Not very original throwing a de-tuned ZR1 motor in there, but I love the fact that the name is back.
still doesn't look like a camaro to me, but don't get me wrong it's a nice looking car but it just doesn't look like a muscle car, and I prefer the challenger :flipoff:
Yeah, but even an SS wasn't that much back then. Inflation is bullsh!t - and gas costs $3.20/gal now... so why in the hell are they releasing cars like this? :roll:
Im sure if you have enough bread to own one of these you really arent worried about the price of gas. Seems like the big 3 are going back to the HP wars of the late 60's early 70's. A gangload of power and can still pass smog....and get somewhat decent mileage. "thumbsup"
The SS couldn't touch the ZL1 (69 were built) back then :ror:
$3.20 a gallon? $2.91 here :flipoff::ror:
I read "technologically advanced suspension" and wondered if they still were using a straight axle out back. Guess not. Good for them...its about time we caught up to the rest of the world.
There is no way they would outdo their flagship Corvette. No company in their right mind would build something that out performs its top performer, even though they could.
They already came close enough with the CTS coupe from Cadillac.
What I don't like is putting the gauge cluster down infront of the shifter.:roll: I'd rather keep them at eye level, but that's just me.
Nice Camaro....I dont think anyone is gonna be dissapointed with the performance of the motor, My CTS-V has more romp than you will ever need on the streets.
