Wiring Diagrams
Note: None of these diagrams show the stock lighting controller. It only requires a 4-6v power supply so any open port will work or you can direct wire it off your BEC (as long as you are running appropriate voltage) or your ESC's red RX wire.
Standard stock setup WITH BEC.
Note that you need to pull the red wire out of the plug from the ESC so that you do not burn up the internal BEC in the ESC. Just pull it back and tape it, you will need to be able to reconnect it to program it via a Castle link or Hotwire if your ESC is compatible with that (stock ESC can use a Castle link).
A typical 2 servo system.
