Thanks.
Yeah, I wasn't able to install the servo, I have the shifter wired into place in low gear right now, and have a single-speed 370 setup on the way.
I also need to go through and measure all the hardware so I can order the correct stuff, it's kind of cobbled together at the moment.
Sent from my SM-G970U using Tapatalk
What if you fabricated some frame rails like the C34 has where the bottom is completely flush so you don't have as much hangup. That would also give clearance for the shifter arm
