WPL C14
Nice! I will grab some of those as well as the rear shocks from the Losi if I can get that seller to just sell me the 60mm ones. That way I can design a mount to fit multiple offerings. Thanks for the link!
Edit:
I wish someone would design some nice oil filled true-to-scale shocks for these trucks =(
70mm shocks work best if you make a riser plate to mount them above the frame. I think someone will eventually design since I don't see this craze slowing down anytime soon. There were some marketed for these trucks but they are too short and the thicker ones were from a WLToys a959.
Here's a video of someone using the LC racing shocks which you could probably use as a guide for mounting the MiniT shocks
Link: https://youtu.be/PURW38VlWto?list=PLDKAf6sBmWW-HU8bJFSP8zR9ZLnWs9xs7
Welcome to the family! I think I'm the only one who frequents this forum as much lately. I have heard that Mini T shocks work, I have a friend who has a bunch. But these are cheaper and would require less modification to fit since you could fit the stock springs
I'm working a new job and haven't had much time but I still check in "thumbsup"
Yeah, I have seen those. Might have to grab one just to learn how to make them.
I might pick one up just for the reverse lights and brake lights. I'm not the guy who puts on his turn signals every time I veer left or right
I still read also. I plan on running some shocks pulled off a Dromida SC18. New aluminum chassis rails are in the works that will add higher shock mounting points...
Also need to design some new axle trusses / link mounts, and finally make a decision on what I'm going to use for links...
Also on the radar are new braces, and maybe even a new CMS/front motor setup. Anyone know a similar scale vehicle that runs a smaller 3-gear style transmission? (1/18 scale 2wd SCT maybe?) Looking for a source for gears to design around...
Sent from my SM-G970U using Tapatalk
I don't think anyone make a 3-speed transfer case in this scale. You can use these links and metal trusses (I think that's what they're called)
The SC18 shocks are about the size of the A959 shocks marketed for these trucks. I don't think there are any externally sprung shocks that are soft enough for these to be honest. That's why I go with the LC racing shocks
These links are the ones I'm going with
Link link: https://www.ebay.com/itm/DIY-Metal-...031366?hash=item3d9217b186:g:jlkAAOSwxgZdZLFU
I have the exact same shocks. I have been meaning to dig my stock Dromida shocks out and and see how they fit. I have a brushless DB18. Nice little rc's. I think they have been cloned by WLToys in the 959 series right?
Yeah, the forward motor project is WAY in the future, lol. I'm sure I'll have to design the transfer case too.
The SC18 shocks feel pretty soft, and I had them on hand, so I figured it was worth a shot...
I have no idea on the cloning part. I just happened to have a SC18 sitting here. Tried to sell it a while back but they were so cheap initially that it's hard to get anything for them on resale. Figured I might as well use it for parts. I have a brushless DB18 that I'm sure will break some things at some point, lol...
I beat the hell out of mine and they are pretty durable. But I also have all the aluminum upgrades on mine. I mentioned the 959 because you can't get parts for the Dromida as easily anymore. But if those Dromida shocks work, the WLToys A959 shocks should be identical. Just guessing though.
Maybe in size, but the 959 stock shocks don't hold oil very well and they have metal shock caps
I have been modeling up the chassis to make it easy to design 3d printable parts for this truck, and 70mm looks to be a bit long for these trucks. Do you have any pics handy of 70mm shocks on a C series truck?
These are the shocks I was referring to.
A959 Shocks
They are 65mm, and I have these on my Dromida. They are nice shocks, and mine have had the same oil in them for 5 years lol. And they are dirt cheap. I am going to throw my stock shocks back on the Dromida and see how they do on the C14.
So I'm working out a little plow to go on the front of my C24. All I need now is some snow in the forcast...
