scottyrock
Thank you, the tranny has the metal gears all ready, so I am ordering a 96t spur ASAP......Thank you, this site ROCKS MY SOCKS OFF
I simply removed the spring and replaced it with a shock spacer after I dremeled off the little "notch" part. Fit in there perfectly. I've been running it that way for about 4 months now with no problems....and no clicking!
Those black plastic snap-in, "C" shaped things.
Another quick but not as cheap fix would be to replace the top 2 tranny gears with mod1 pinions.
15t up top uses its set screw to stay in place, the middle shaft was a bit more work. I got rid of the stock smaller shaft and replaced it with a 5mm final drive shaft from a t/e-maxx tranny cut down to size. Then a 22t pinion there. Tranny is super smooth and strong as hell. The big 28t might give up though. Then ill throw another mod1 pinion in its place too.
Exactly what happened to mine. I fixed the slipper setup and it ends up clicking in the rear axle. I don't have 2 minutes of run time on this thing and they stripped already.You might want to look into your rear diff. I thought mine was the trans. till I pulled it apart and did the slipper fix. put it all back together, went outside and the first rock I tried, the clicking started right up. So I pulled the rear diff. and sure enough, ring and pinion gears are stripped. My sons wk just started the clicking, so I'll be taking it apart tonight to fix his. Hope this helps
