What powers your SCX10?
Associated sc700-bl esc with drag brake set to 100%, novak ballistic 21.5 brushless motor with 14/87 gearing, an variety of batteries, 2s and 3s.. And shes a beast!
RC4WD 35t, tekin fxr, two 1800 stick nihm batteries, 18 tooth pinion stock spur, stock drivetrain and Futaba gear.
Castle MMP esc. Tekin 13.5 redline with 13 mm hi torque rotor. Gens ace 3S lipos. 14/36 overdrive axial hd in axles. 14/88 pinion robinson slipper/spur . Goes like heck and can still crawl.
FXR, Novak BEC running a HH 35T handwound on 2200 3S batteries. MIP driveline and Robinson Racing one piece center diff and idler gear. Also mirrored and flipped tranny. 16T pinion and 87T spur gear.
Pure Awesomeness powered by Kush and Busch
M2 Dig esc or Axial AE-2 esc, 100% drag brake
Integy 45t Matrix Pro Lathe Motor
Robinson Racing 17t pinion, RR 87t spur
Robinson Racing tranny gears
2s Zippy 40c 2200mah LiPo or 3s Traxxas 30-50c 5000mah LiPo
Holmes BRXL WP, 27T Holmes TorqueMaster, Thunder Power 2700 3s lipos, MIP Driveline, Robinson Racing Pinion Idler and Center One Piece Hardened Gears
Are you fellas dropping these different brushed motors in with the factory esc? I would like to do a upgraded motor, Hoping to drop the motor in only...maybe a bec for 3s power.
Any suggestions? thanks
Stock AE-2 ESC.
Stock 27T
19T pinion
(2) 5400MaH 2S 20C Lipo
Spektrum DX-3
I get about 2-2 1/2 hours of run time per battery.
