Would like to see a HH motor with 4 holes beside this photo with circles around which holes to use. Then this photo with a 9T pinion.
I got the Traxxas labeled 9T. I saw other brands but this looked the best machined and shape. There is a little noise from the truck but I do not know if it is the HH motor or the pinion. The motor I got on eBay did not have the new sticker for advancement. I moved it back and forth listening where the most power was..then backed off a little so reverse would have decent power. The HH motor had 4 holes. I picked two stacked on top of each other. Tried 9T with the 45T slot and did not match the motor hole. Would like to see an install video from someone doing just that with clear closeups. I found two that seemed to work. Placed the spur gear with the Allen facing the motor. Made sure the Allen did not touch the spur gear. Mesh looked good but I could not get a good look with the way it is bolted in. This rig is a beast now. Stops 3/4 up a rock and just sits there. Slow crawl is like slow motion. It crawls so slow that the default motor noise on my sound box does not know the motor is running till 3/8 throttle sometimes....need to recalibrate.
Tried the 70/30 with the stock transmitter. Reverse was not coming back to neutral...had to bump it. Went back to 50/50. I like the instant control. It still has enough range for me to do amazing slow crawls.
Will most likely do a 60/40 with the DX5 Rugged.
I will use HH website for the next purchase.
I checked the foam I make inners from...much denser than stock. How goes the foam battle BenP ?
1 more thing.
If you’re looking at getting an aluminum motor mount don’t get the 1 piece one like traxxas one.
Get the 2 piece mount like this.
Much much more solid mount. My friend got the aluminum traxxas one and said the motor is still wobbly like stock. Maybe a slight improvement.
I got the 2 piece GRC mount and it’s rock solid.
Something to keep in mind.
Benp, do you have a link the two piece mount ?
Thanks, Uncle Pete
I've used one of the cheap CNC alloy ones and the GRC. No difference I could tell. Amazon has some of the CNC style in stock if you don't want to wait for shipping from overseas.Uncle Pete,
This is the same brand I have. I got it from Asia tees though not from eBay.
https://www.ebay.com/itm/273646680815
Unfortunately it’s not an inexpensive item. I remember paying 30 something for it.
That being said here’s a cheaper one made out of alloy. I don’t know if there’s a big difference
Between alloy and aluminum strength wise though.
https://www.ebay.com/itm/392580825369
You know, I've seen trucks running massive droop and no springs. I'm not exactly sure why you would do that. I've even seen trucks with the shocks installed upside down. People do all sorts of crazy things. Oh and pen spings inside the shock body too. I guess it depends what you're going for. No spings would be useless for a trail truck but maybe it's better for on the rocks? Seems to me that springs help push the tires down for traction.? So much to learn about this hobby!Back to messing with the suspension trying to figure out a good droop setup with 110mm desert lizards.
Good droop but I had minimal preload/dampening.
Lots of tinkering ahead. Lol
A little tedious but I find it a better tedious than mounting tires. [emoji1787][emoji1787]
It’s raining today so I figured this is a great project.
https://www.amazon.com/dp/B081YHY796/ref=twister_B081YHYW78?_encoding=UTF8&psc=1
@Benp
Did you mount the desert lizards in the same hole as your stock ones? Or a lower hole for even more droop? Was the binding on the driveshafs an issue?
Over all it sounds like a pretty solid improvement!
Also, scraping lexan is like nails on a chalk board to me. Bumper looks good [emoji41] You dont run one on the rear at all right? At least, not until your vanquish ones arrive?
That’s good news. Don’t you love it when a plan comes together !
