New hubs showed up for my new to me SSD Assassins and new Pro-Line Predator Trenchers and dual stage foams.
Ran into a snag, for whatever reason, with wheel fitment and my front SSD portal brass. The wheel was contacting the little hump on top. So I took a raker file to it.
A few passes later , we are in business.
Now it’s out to my slick granite rocks for a shakedown of the new tires.
These are amazing for not even “broke in” brand new tires and foams. I mean AMAZING!
My Predator Hyraxes do very well on my rocks but actually slide here and there on the slick granite. While not brand new, they are not shot by any means and do better than my Landmines.
The Predator Trenchers are above and beyond the Hyraxes. The compound and the tread pattern equals solid solid win for me and my granite walls.
Normally this rock will get the rig sliding when transitioning from the red but you can drive out.
Trenchers stuck it!!!!
When going backwards and stopping the truck would usually keep sliding a bit because of traction.
https://youtube.com/shorts/3_qxf5tmymQ?feature=share
The big red rock before the big white one is bar non the slickest rock in all my walls. I’ve had the truck just slide right off when stopped. Again the Trenchers nailed it.
https://youtu.be/Q6pNIMsoJfU
I have never ever ever shot this line before with the hyraxes. I consistently did it with the Trenchers and actually went up and over a few times. Amazing. As luck would have it, when I realized I should film this, my touch tooo small SSD front driveshaft came apart as I was heading up and out.
https://youtu.be/IE5Ix-REygc
Speaking of the front driveshaft. The stock one would bind and chatter when the front was fully extended. So, I got the SSD front driveshaft because of operating at 50 degrees. That being said, it’s a bit too short with my long shock setup and will come apart when things are just right.
I picked up IERC scaler front shock keys a while ago to get the front shocks raised up and laid back. This really dropped the front down. So after dealing with the Ssd coming apart again tonight, I decided to put the stock one back in. So we will see how this does.
Long story short, Predator Trenchers are fantastic on my rocks and I can’t wait to see how they do once broke in.
Here on out, these will be only tires I get.
