What did you do to you SCX-10 today?
Got the bumper and light bar the way I like it, and switch mounted to frame. Now I just need to figure out a more solid bumper mount to the frame.
Installed SSD front and rear metal drive shafts :D and more lights.
Sent from my SM-G930F using Tapatalk
Changed from Mad Beast to Rock Beasts. Significantly better grip on both dirt and rocks, it seems to me. But the front axle takes a helluva lot more beating because of less ground clearance.
Chopped and bobbed the old Honcho flat bed for a new look and better depart angle
I like how it turned out
Sent from my SAMSUNG-SM-G891A using Tapatalk
Messing around with the leftover plastic tube pieces from my flatbed hack job and mixing in a little of my traxxas slash rear bumper
I need to learn how to braze metal
New wheels and tires for the rig. Proline Flat Iron XL with CI Firm rear and Med front. Also added a set of Proline Powerstroke scale shocks recently.
Made a set of plates for the outriggers to hold the battery and electronics finally getting all the weight off the back axle....
Also added a Heyok light controller for 4th channel control from the TX.
Took it for a swim. Ultimately ended up smoking the ESC somehow. Battery submerged during a rollover and the ESC went poof. Managed to unplug the battery before any actual flames started. Still not sure how the ESC died. Oh well...
Took them out for a little run today. The upgrades did excellent. Need to change the foam to the 2.2 to run with those bigger rims, even though the tires are 1.9. Even with the extra play it stills side hills awesomely
Sent from my SAMSUNG-SM-G890A using Tapatalk
Ordered a complete set of fast eddy bearings for the build since I'm replacing so much with upgrades. Also got team associated shock stand offs for the new shocks that need to be ordered
STRC stage 1 kit- black, Boom tubes in both axles, STRC CVD'S, STRC gunmetal front & rear bumper mounts, and STRC axle trusses fr & rear (its ok! Running servo on axle still w 4 link setup).
