Nice skybolt! Are you done building it yet?
ive always wanted to try this https://www.youtube.com/watch?v=pfFn3aUQ7S0
Wow you already got it back from tekin? That was fast!Well I give up. New sensor... truck runs the same.
Robert. I tried that. reset the esc to default. I have tweaked it to the point theres no reason to tweak any more. I cut the power down to 70% punch control is at 40% timing is at 0. I even turned up the drag break to 60%. still no low end control. you end up having to give it more power to get it going then it needs. Then your on the breaks trying to slow it down. I cannot get that fine low end control like you guys have. I got it to stop blowing the tires up trying to get over stuff. I don't get it. Im taking it out. Im done with it.Wow you already got it back from tekin? That was fast!
No I bought a new sensor. If Skybolt only knew how easy it was, he would be kicking himself for sending it out to be done. 3 screws takes off the end cap. 3 screws frees the sensor. change bearing to the new one. put it back together.
~ Engine building ~
Since building the Fuel Cell in the back for the MMP ESC I wanted to have a custom box for the RX, LED and BEC up front that resembled an engine.
You have no idea how long I spent working on this in the CAD software...
(Version 3) I printed two other CAD versions before I got to this.
The bottom hole is for added space into the oil pan.
Lexan oil pan from Speedweigand
The "Master Plan" will be to print a second one and take my time to paint it up as nice as I can with some detail; until then this will do.
I also filed down the "Level3" shock mounts to allow for the hood to be closed without chopping holes in it. I hope I can get this thing on the trail before snow flies... I'm going to run it without an interior once I get the electrical done.
