Bump on the above. I've more often seen Plastidip used on external components and dielectrical grease / liquid tape used on the internal components like circuit boards ect.
Has anyone used Plastidip on the internal circuit boards also?
To summerise if anyone else opens this thread and to check with others i have this right.
To prep your vehicle for water....
- Dielectric grease is best for the connections like batterys, reciever plugs ect. Can also be used on the boards directly and isn't pernament.
- Teflon or other types of silicone grease is best for repelling water around areas that are harder to seal (i.e servo external gear)
- Marine grease is best for repelling water from parts that might rust (but not too much or it'll cause too much friction)
- Liquid tape is better than dielectrical grease as a more pernament method of water proofing for circuit boards.
- Plastidip is best for providing a water proof seal on external enclosures
Could someone confirm / correct me on the above before i make any expensive mistakes? "thumbsup"
1. Yes dielectric grease is fine for connections. I stated above in a post that I don't find it necessary. The plugs carry current but not enough to cause a short underwater. This has been the case for me running deans plugs on 3s lipos. I don't worry about plugs at all, dunk 'em.
2. I'm not familiar with teflon grease but I think you've got the right idea. I recommend opening up the servo and coating the circuit board with liquid electrical tape or plasti-dip so that if water does make it in, it can't short out the electronics of the servo as easy. I use either dielectric grease, marine grease or vaseline to go around the servo horn externally. Something thick will stay on better and not be washed away by water/mud, etc. You can also put a big glob of grease on the output spline shaft of the servo before putting the top of the case on to help seal inside at that point of entry as well.
3. I got some marine grease from Ace and i like it. I pack the axles and trans with the stuff to help keep water out. For me it has kept the bearings and internals in good shape. Nothing keeps rust away like some good old fashioned maintenance. I do try to assemble the truck without the motor hooked up and push it back and forth on the floor a lot to loosen up the grease from the gears, it does put a lot of drag on the drivetrain.
4. I also use liquid electrical tape. Other than the FX-R I had catch on fire (I believe from clogging the motor up with sand/mud) everything I've coated with liquid electrical tape has been flawless. I recommend several coats, let it dry for 30 or so minutes and look it over, little pores and holes open up as it dries, so recoat those areas and make sure it's sealed (especially if it's an expensive ESC, etc.)
5. I bought a can of plasti-dip and never opened it. I think it's yellow and I realized I don't want that on my truck. I use liquid electical tape on external seals as well (like the seams on servos). I think it dries a whole lot thinner than plasti-dip but it works good for me.
I've found over time that I prefer to bench test my waterproofing. It's a lot less frustrating than going out on the trail and something gives out and you wonder a million questions... is it the ESC, did the servo get wet, maybe the receiver shorted...etc. If you sit on the bench, power everything up and dunk one item at a time, you'll know it's good. Things still go wrong but it makes you more confident of your waterproofing job.
