viper's creeper build
they were in a pit box full of parts when i bought a group of vehicles and parts , they are aluminum and seem to be good quality i still have four more in my pitbox ( think they were for a rc10t3 or 4 ) now if they were just green
right that would be sweet if they were green!!!!! I like how they are not taking up much room the minumim material the better.
Theres another relatively cheap way to test long term is to go by your local sign shop and buy some colored vinyl sheet,,,you can cut it out and fit it to the chassis itself or to the back side of lexan body panels or the body itself if you run a body.
oh i almost forgot while i was working on the creeper i had the chance to weigh the wheels they weigh in at 6.93 oz without tires and foams the tires and foams weigh in at 3.89oz so together it is 10.82 oz . i added 2 oz of lead weights to each front wheel to make it 12.82 oz we will see if that is enough i am approaching the weight slowly as i would like it to be as light as possible yet perform well .
well i finished fifth in sportsman today , still need to add some more weight but it was alot better . started on the 2.2 pro course was third of the way through took a tumble landed on my top so rocking back and forth to get on my tires when all of a sudden a loud snap was heard by everyone standing around ( day over ) front axle shaft right at the cv snapped like a twig . one positive note the rear solid axles are still going strong no bend twist or breakage so far .
and you all may shoot me but i am thinking about switching to an axial tranny and a slingshot chassis ( maybe still considering )
okay question has anybody had a problem with aftermarket wheels not fitting on creeper hexes due to the little protrusion in the center of the hex ? do i cut it off or do i attempt drilling the center hole on the wheels bigger ?
just a small tip for anyone, the front wheel hex and pins from a traxxas stampede fit on the creepers minus the little stubs that get in the way of some aftermarket wheels...if you think that you can live with plastic hexes then the traxxas stampede wheel hexes are a good substitute (plus the traxxas hexes are a little wider to give your rig some with for help on side hilling. hope this helps someone.
okay just a brief update for everybody , i am looking at a chassis and working with it's designer to see what it is going to involve to use it for the creeper ( so i may be driving with a company name on my rig ) still not sure about the tranny change still thinking . as it sits right now the creeper is in several pieces on my work table . future updates as they are availible.
also the axles have held up great , as soon as i can i will be posting a pdf file of the plans for the axles so anybody that wants to can have a set made .
the fact that venom and other vendors keeps ignoring the creepers transmission weaknesses, i dont blame you at all. i havent broken anything on my trans(and i only run my rig about 2 times a week) but i just dont have any piece of mind that it will hold up even with a simple 55t motor...and ive heard enough stories of gears stripping to make me worry, and i dont drive my rig as hard as some of you guys but i would like to without worry.
Well,,I dont know where your worries come from but let me tell you this...Ive been beating on my Creeper with a 55t/19 tooth pinion on 3S for months....its better than any Axial trans Ive seen.
thats good to hear...i think a lot of my own worries come from the fact that alot of my rc experiences come from a few buggies and a couple of monster trucks. with that being a majority of my rc experiences its hard for me to shake the "metal gears are better" influence. its not fair to the creeper or to rock crawlers in general but i hope my creeper will prove me wrong.
