viper6171
yeah we had two sportsman and two 2.2 courses each had 8 gates per course and both courses were pretty brutal , i have some more pics of the courses i will posthey Viper,,,,were the Sportsman and Pro courses seperate?
nope it is actually a softball park in independence ,mo. if you look in some of the pictures you will see some of the decks used by the parents to watch the games these rocks come right up to the side of the fieldsWith the rocks being down in like that it looks like an old zoo or something????!!!!
i have lived here all my life grew up in independence about a mile from where these pics were taken , i really do love it here , you will have to come back sometime . where at in kc ?This really makes me home sick bro....KC born and raised....left in '77 and came to Colorado.
well like i posted earlier the 10x15x4 hub bearings were bad but i found another problem i guess the pin holes in the axles ( for the hexes) are just a little off ( to close to the hub ) so when you tightened the wheels up the hexes were pressing against the hubs and putting alot of pressure on the inner bearing so i found some different hexes for now that the slot in the back isn't as deep as the creeper hexes ( fixed that problem). we are having another comp this sat so i will see how it works now ( also drilled vent holes in the wheels so the tires weren't air filled balloons ) still need to move some electronics down lower to help with cg may also find a new home for the battery .
not sure what they came off of they are plastic and black thats about all i can tell you for sure , i am probably going to have the stock ones machined down a little bit or find another set of aluminum ones that will workI had the same problem and your right the hex are too deep good find what kind of hex are you using now?
:lmao:well make me a team driver and then it won't " bug " you "thumbsup":lmao:Looks good....but man,,,that body bugs me...
