viper6171
okay well the last comp didn't go the greatest i finished second to last , the rig just didn't seem to perform well. so today i sat down and went over everything to see what i was missing , well i found it ( actually three problems ) the steering link seemed to be to short ( had too much toe out ) my rear shocks were sticking and they were rubbing the upper links when flexed . i also had a problem with my front driveshaft coming apart (the end kept popping off the u-joint( at one point it popped out so hard that it hit me in the leg ) so i finally made a new longer shaft for my hr driveshaft so it would fit .
so i proceeded to tear apart the rear suspension so i could fix the issues , to start i moved the upper links rear mounting point to the inner mounting point on the truss . i then put spacers on the front mounting point so the angles would stay the same . now to turn my attention to the shocks , one of the shafts had a rough spot on it so i chucked it in the drill and cleaned up the shaft with 800 wet/dry( nice and smooth now and no leaks ) .
after i reassembled everything it works nice and smoothly now( no bind no rubbing ) , then i took the steering link apart and added spacers to both sides . while i was working on the frontend i replaced the ripped out c-hub screws with 6-32 screws for now ( i still left the zip ties on it as well ) .
so maybe now after all of the work it will crawl better................. more testing to follow .
