Venture Max Gear down Motor Mount
HumboldtEF
Tiny truck hoarder
Lifetime Gold Baby!
Humboldt county
I've made up a replacement motor/servo mount that will allow gearing down to a 10T pinion. modifications to the motor plate are required.
I've uploaded the motor mount to Thingiverse where you can download it for free
https://www.thingiverse.com/thing:3569491
There are some things to keep in mind with this print, there's one hole needing tapping as I simply cant add any more material to get clearance for the max gear down (which is the whole goal of this). This hole may split open even if its tapped but it can be glued up with CA, install an M3 in this hole when doing this. Even after splitting this hole I didn't have any issues stripping it but be careful not to overtighten.
the stock button head screw needs to be replace with a 15-16mm socket head M3 for clearance.
You will also need to slot the motor mount holes. The center hole and the slotted hole need to be extended along with the plastic piece to get as low as possible. I didn't measure but i think it may have been 3-4mm in the center and 4-8mm on the motor mount slot/hole
You will need to install the servo and spacers before you connect it the the transmission.
I also include some 5mm servo spacers in the download that correct the steering geometry and align the steering and panhard links. If you use these you'll need four 15 or 16mm tapered head m3's. The servo mount also requires four M3 locknuts.
