rohrej
Watched Josh build it, gear to spool, slide bearings onto, follow with retainers, drop in. Could caps be reversed side to side ?
That was my thought as well, caps looked odd to me in the photo.
I'm not sure if you mean swapping the two retainers, or that they are flipped backwards.
I've tried swapping them, no difference. The bearing cannot be inserted at all if the retainer is flipped the wrong way.
Keep in mind, the assembly that works in the rear housing, cannot be installed in the front housing.
