iota
Hy
I make crawler parts in my spare time.
Here is what I have in stock:
--- Twisting chassis ---
---clic -------clic -------clic -------clic -------clic -------clic -------clic -------clic -------clic---
I've made this chassis for the XR10.
The idee was to make the high parts of the crawler ultra light to have the center of gravity as low as possible.
The chassis has no suspention and weights only 86g = 3oz.
The center part is made of flexible PE but the geometry and the two long links made of POM makes it verry stiff and precise.
It is only the rear part of the chassis that is bending to get the twist.
My crawler with this chassi and two small outrunner weights TRT 46.5oz but I add 2x 3.5oz weight at the front.
The chassis is available in white and Black.
The first pictures are here to illustrate how it is buit up.
I sell it 135$. Shipping is free.
--- Low weight ---
I've made these weights for the XR10.
The weight is verry low on the knuckles to get the CG as low as possible.
2x 3.5oz (100g) left and right for the front axel.
You have to drill one 2.5mm hole in each weight. The material is soft. So you can fit it to your tire position.
I sell them 27$. Shipping is free.
--- 2.2 carbon wheel ---
Light weight wheel for 2.2 crawlers.
They are made out of 7075 Aluminium and 2mm carbon fiber. The wheels are 25mm wide.
You have to glue the tires on the wheels with only a few dots. The tires are not included.
The hub is for XR10 and does not fit the VP patern.
The four wheels are at 108$. Shipping is free.
If you have any questions feel free to ask.
--- Low weight ---
