U4RC Current Class Specs/Rules
So I am building a truck, plan is to use a bunch of old 1/8 buggy stuff I have. Igs buggy front end to stock center diff. Use the stock chassis but trim down the sides and cutoff the back. Install link and tube chassis mounts... Wraith rear attched to the links and tube upper chassis.
Question is, is this legal? If so what class?
Also on wheels, the rules don't really spell out what's legal the day I read it. I was hoping to use the stock 17mm hexes, but there is no way to make those work with a vp wheel, I was gonna fav some type 3 piece wheel out of an older buggy wheel.
Thanks
Later EddieO
What you are describing could fit in either 2.2 Trophy or 2.2 comp. If you can make a 2.2 wheel tire combo fit you could go trophy, if you must use a 2.2/3.0 wheel it would have to go into 2.2 comp. 1/8th buggy wheels are illegal in all classes.
My idea for the wheel was to make 3 piece by cutting the hex mount area from a dish wheel, then make bedlocks for it...
Still a bit confused on what 2.2 wheels are legal and what are not.
Later EddieO
Later EddieO
As long as it is a 2.2 wheel with a scale 2.2 tire and not just a solid dish wheel you should be good.
*At this point there is no motor type or limit rule in any class. Too big of a motor can actually make getting around the track more difficult.
*Shafty type transmissions is the rule in all classes. Single or multi-speed are allowed.
*There are no battery size/cell limitations in any class. the only rule is that it must be hidden in a scale fashion and chassis mounted.
These rules will stay thru the 2013-2014 Winter Series. Hope this info helps...
Is the rule on "no motor limitation" still current for 2014 and for future 2015 races. thx
Yes it is. In our opinion a given car can only be so fast around a track based on things like suspension and CG. We have seen more people change from say, a 4600 on 3s, to 3000 on 3s and be faster than before.
Newb question for this type of racing....I have a Traxxas Telluride I'm going to build...was just going to be a toy but wondering if it even has the possibility of being competitive in the 2.2 comp class???
That's a good question.
To date we have not heard of anyone running a Telluride at U4RC races. As long as the rig specs meet the class requirements I would give it a shot."thumbsup"
Sorry for the delayed reply, have been super swamped for the holidays.
We are in the process of building a U4RC track here in VA.
Im looking for info on rules and regulations.
Every time I click the link for the rules it comes up blank?
Any help would be appreciated.
Thanks!
Sean
Thanks!
Sean
Looks like the page background and the text on it are the same color so the rules are actually there just coded white.
If you scrape that whole page the rules will be hi-lighted.
Kinda sucks but maybe you can just cut-n-paste them into your favorite editor on your personal confuser.
Gonna need that decoder ring after all. I can't for the life if me get the rules to be legible.
Can some one please fix the posting so the rules can be read?
Thanks!
