willyrocket
Now, if we could find and endless supply of axle housings...... We would be set.
willyrocket said:Now, if we could find and endless supply of axle housings...... We would be set.
I've been thinking of getting a set of Twin axles, but I have some questions.
1. How long will the stock diff gears hold up to abuse? Should I replace them right off the bat?
2. Stock hubs are 17mm, correct? Is it worth replacing the stubs with Savage's, or just use wheels with a 17mm hub?
3. Should I replace the spiders with stronger units even if I am just going to JBWeld them together?
4. Is there anything else I need to know about them?
Thanks. BTW, I would appreciate the help ASAP (tower savings offer ends today. :lol![]()
Is there a 14-17mm adapter?
Use 1:8 buggy hexes
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBZP1&P=M
Anyone have a exploded veiw of the axles with PN's. None of the 1st post pics work or that would probly help a a ton.
Was just looking at the Maximizer Locker #2356. Does the CEN LOCKER (ceg-gs013) mentioned earlier also work well, direct fit?
Thanks
