microgoat
Yep, you read it right. As in Twin Traction Beam, Ford's funky split solid axle. Why? Because it's hard to do. There sure isn't any advantage from a performance standpoint, but since I'm putting a Blackfoot body on this, I wanted a suspension under it that would be true to form, and TTB seemed to be the way to go.
I've started with an aluminum ladder frame using the bottom of TLT side plates as link mounts. The rear axle will be leaf-sprung. Both axles will be mounted upside-down to accommodate the swap over to a driver's side pumpkin on the TTB, which means I'll have to reverse the rotation of the motor.
The TLT axle has been narrowed 1/2 inch on the left (shown glued in the mockup shot, it will have an aluminum plate spanning the joint for reinforcement) and uses a Tamiya Mini Cooper dogbone and a TLT outdrive on a chopped axle shaft. The swingin' side gets an HPI 50mm dogbone, which had to be trimmed to fit inside the TLT drive cup. Both axle halves will get hockey-stick shaped brackets that attach the axles to the frame. The left side will also get some spacers so it doesn't bind when the two halves articulate.
Since it's a scaler, it won't need a whole lot of travel. I'm using Mini LST springs; at least I think that's what they are. I found 'em in my spring box. They're short and soft. If I go for ultimate scale, I'll pop for a set of Mini-T shocks (like TLT shocks ain't leaky enough) :roll:
blah, blah, blah, here's the pics:
