SDS Customz
<HR style="COLOR: #191b21; BACKGROUND-COLOR: #191b21" SIZE=1> <!-- / icon and title --><!-- message -->
Pre-Sale "Ti-Fighter" "Al/Ti-Fighter
Due to the expensive nature of this product, these will be a pre-pay product. Once I have recieved 10 orders then I will forward that to the machinist(In order to keep any sort of price point).
What you will recieve-
Aluminum version-case halves and tubes will be made from 7075 stock/All other parts will be made from 6061 aluminum.
Ti version-these housings/tubes will be constructed from 6al4v Ti. The rest of the parts will be made of 6061 aluminum.
Parts list-These housings will be sold in pairs only.
1-front axle case-highest clearance berg cases available
1-rear axle case
2-front axle tubes-smallest diameter tubes in the industry
2-rear axle tubes
2-rear axle lockouts-the smallest in the industry affording the highest clearance
2-rear axle bearings(10X6X3)
2-rear axle retaining clips
2-6mm rear axles-couple our axle design with 4340 chromoly and you get the strongest rear axle available.
2-rear axle lower link/shock mounts-designed to be clockable with improved mounting points.
1-rear axle upper link mount
2-front axle tubes
2-front axle clockable "C's" with 50* mechanical steering stops designed for Vanquish knuckles.
1-front axle upper link mount with integrated servo mount
1-servo brace(designed for use w/400size motors)
2-front axle lower link mounts
2-front axle outer knuckle bearings(11X6X4)
2-front axle "Super 300's" for "Ti-Fighter" w/your choice of stub style(Berg/Axial)
2-lightweight lockers
2-Motor adapter plates (drilled for both 400's/540's)
New lockers(3/8"narrower)
Case halves/link mounts/C's
Servo mounts
Assembled front and rear axles
Comparison pics between Berg housings and TI-Fighter.
Some of the above pics are of prototype parts(slightly unfinished). They are only intended to show size comparison
*note-all product delivered to the customer will be raw machined aluminum or Ti (not black as in the pics above)
Parts you will need to provide to complete your housings-
all berg internal gears/shafts/bearings
These parts are all constructed from the highest quality of US made materials. In a machine shop here in the US. These parts are all made to exacting tolerances.
If you would like to order "Ti-Fighters" send me a pm and I will get you a paypal addy. Pricing is as follows-
Al/Ti Fighters-please see vendor section for pricing at the following http://www.rccrawler.com/forum/showthread.php?p=2839809#post2839809
Ti-Fighters- please see vendor section for pricing at the following http://www.rccrawler.com/forum/showthread.php?p=2839809#post2839809
Please post all questions in this thread so I can answer them one time. Thanks for lookin
<!-- / message --><!-- sig -->
1-rear axle case
2-rear axle tubes
2-front axle tubes
Servo mounts
