Thanks, guys, for the tips about the TRX-4 shock springs. After days of careful research (or maybe wandering on the internet for half an hour), I've made some discoveries that I'll share here. Maybe well known already, but who knows, could help someone else since it was more painful than I expected to collect.
The stock shock springs for the SCX10-2 kit are:
For the front: AX31145 (yellow), 2.63 lbs/in
Axial Racing - Spring 12.5x60mm 2.63 lbs/in - Yellow (2pcs)
For the rear: AX31441 (white), 1.13 lbs/in
Axial Racing - Spring 12.5x60mm 1.13 lbs/in - White (2pcs)
We're going to start by matching the TRX-4 springs to the stock Axial springs, partially since we may sell the kit shocks for other upgrades and I really have no other idea where to begin. I also like the looks of the black Traxxas springs, which is reason enough, ;-)
The TRX-4 springs are listed with a unitless "rate." I think the units are N-mm; please correct me if I'm wrong. There's an on-line tool for converting between various spring rate units at:
.: Spring Rate Conversion Calculator :. | NorWest Suspension LLC
I can't attest to the accuracy, just assumed the conversions were correct. The results were reasonable. Plus it's on the internet and so must be right.
The TRX-4 options are:
TRA8042 (yellow), 0.22 rate, 1.26 lbs/in
http://www.rpphobby.com/product_p/tra8042.htm
TRA8043 (white), 0.30 rate, 1.71 lbs/in
http://www.rpphobby.com/product_p/tra8043.htm
TRA8044 (orange), 0.39 rate, 2.22 lns/in
http://www.rpphobby.com/product_p/tra8044.htm
TRA8041 (no color listed), 0.45 rate, 2.57 lbs/in, stock front for the TRX-4
http://www.rpphobby.com/product_p/tra8041.htm
TRA8040 (no color listed), 0.54 rate, 3.08 lbs/in, stock rear for the TRX-4
http://www.rpphobby.com/product_p/tra8040.htm
TRA8045 (blue), 0.61 rate, 3.48 lbs/in
http://www.rpphobby.com/product_p/tra8045.htm
Note that if you look up the TRX-4 springs at AMain, their spring table lists TRA8042 twice. The second one is the stock rear spring and should instead be TRA8040.
It's pretty easy to distinguish between the stock front and rear TRX-4 shocks if you squeeze the shocks in your hand; plus I confirmed my conclusions with a completely legit blind squeeze test with the kids. "thumbsup"
The stock TRX-4 fronts (2.57 lbs/in) are very close to the SCX10-2 stock rears (2.63 lbs/in), so we'll use them without changes for the rear. I bought a set of the TRA8042 springs for the front - not exactly the same as the SCX10-2 springs, but within 10%, so I'm guessing we won't be able to tell the difference.
I'll give a noob-ish report about how the shocks perform once we have the truck together. I think the driveshafts are the next step for us.
